firebird672002
- Sep 29, 2008
Hi all. I've been a member of this board for years and I've learned alot but this has me stumped. I have a EA Stage 2, about 3 years old. I had a bit of a sticky TV valve when warmed up. So I figured I would take out the valve body and clean it up, change fluid, filter etc. When I got it back together, all gears are fine except- reverse. The car will barely move in reverse. Wheels will spin if on jack stands. Also I did check the low gear overrun and that does NOT work either. So, its a low/reverse issue. I tried pulling the TV in and out in reverse and no luck. I checked the pressure regulator/boost valve assembly twice and its correct. Check ball placement should be right. What am I missing? No issue with reverse at all before this. Ideas welcome! Thanks in advance! Here are my pressures.
P 110/275
R 100/200
N 110/275
OD 110/275
D 110/275
2 250/250
1 250/250
P 110/275
R 100/200
N 110/275
OD 110/275
D 110/275
2 250/250
1 250/250
