Guys,
I have a twin-turbo small block 375CI motor that makes over 1000HP w/20PSI of boost. So I have already got a huge fuel system etc. I have temporarily removed the turbos from the car to combat some driveability issues. The motor still makes a shade over 500HP NA.
I was wondering what exactly would I need to do with my SFI fast system/84LB injectors, weldon pump, etc. to be able to use NOS? It would seem to me like a dry system would be fairly easy to construct. Is anyone using the FAST NOS control?
I don't think that I need a hole kit with fuel control etc. It seems that I need a bottle, lines, valves, nozzles and a TB plate? or am I missing something?
Also I am confused as to how many stages of NOS fast can control... the software seems to imply 3. the wiring diagram indicates two... another reference says that if you have IAC which I do... that you cannot use two stage NOS?
Craig/Lance whats up with the NOS? Thanks in advance.
P.S. evenutally the twin-turbos will be going back on the motor and the NOS will probably hang around as well. Geez 1200HP
NO Turbo LAG!
Doug
NO Turbo LAG!
Doug
