Dont you use an electronic controller? If so.. turn down its voltage to the pump and that will decrease the output.
If your running off of hobbs switches, then you can turn down flow by decreasing the pressure on top of the pump.
Dont know if your motor wants 137 PSI on a M15 or 80 lbs on an M10. This requires some trial and error and first is to start at zero knock.. then work on reducing amount.. via pressure.. which is done electrically or mechanically.
How much alky does your motor need? That my friend is the mystery.
Figuring volumes.. doesnt work. Cuase every motor responds differently to the injection. Ballpark possible.
Tell me how much HP your making, your boost, type of system, i'll throw you the "should" get ya numbers for nozzle and pressure.
