Some documents from NVU on installation.
This is a first draft there could be some corrections from the one you receive.
UPDATE 1/15/14
Things to buy:
Casper's 18 way dash connector mate...this is optional but allows installation with out cutting factory harness connector.
http://www.casperselectronics.com/store2/product_info.php?products_id=1500
Speed senders:
2 pulse speed sender from trans to VSS.
http://jaguarsthatrun.com/Pages/SpeedSensors_Speedometer.html
-or from-
http://www.nookandtranny.com/mm5/me...oduct_Code=SEN-FBPVSS-2K&Category_Code=SENVSS
Speed sender from trans to gauge:
These are very common and can be found at tons of different sources the price varies widely.
http://www.ebay.com/itm/like/260778921588?lpid=82
http://www.summitracing.com/parts/vdo-340011?seid=srese1&gclid=CIqb57bVgLwCFbIDOgod-EsA5w
Misc.
Wire 14-16 gauge in different colors to help install the senders under the hood and from the 2 pulse sender to the interior.
Wire conduit/ plastic wire loom to cover the wires under the hood and under the car.
Zip ties to secure conduit.
Electrical tape.
Heat shrink for any connections made, heat shrink is a good alternative to tape.
Ring terminals and misc spade terminals to add POS and Ground as required as per installation instructions.
Terminal strip IF you choose not to use the Casper's connector mate and will cut the harness connector off a terminal strip can make short work of the wiring.
Here is a pic:
Tools:
For Caspers connector soldering is required so a soldering gun/rod with thin electrical solder.
UPDATE 1/15/14
Things to buy:
Speed senders:
-or from-
Misc.
Electrical tape.
Here is a pic:
Tools:
