I posted this problem recently and received some good tips. So I went to remove the two 13mm screws and found they were both lose! I cleaned off the surface and am ready to reinstall it. Two questions-
(1) Does the dealer still carry the gaskets? I emailed Racin Jason but got no reply. The gaskets are on his website
(2) What can I put on the screws so they won't come lose? There are two different types of Loctite, correct? A red and a blue? Should I use the blue so I can remove it if necessary in the future?
It looks like it would be real tricky to just use hi temp gasket maker from a tube (instead of the factory gasket) unless I removed the oil drain from the engine block to get better access, so I would like to try to use the factory gasket if possible. Thanks.
