nothingman
- Mar 24, 2012
good and bad news... while i was priming i noticed oil leaking from the turbo piping? good news there was no metal in the filter or oil and the oil had the normal color. plus the car runs great with no tick, although i still have to pickup a timing light to get the precise timing. it idled at about 50psi then i went to adjust the timing a little by ear and after the car warmed up i checked the gauge, it had an idle psi down to 10psi... i looked at the trans shroud and noticed a little drip forming from the drain hole... i want to take it for a test drive but not sure if the psi is too low and dunno what could be the cause, i don't see any other leaks either?
