RegalT-type85
- Jan 23, 2010
Hi eveybody, My oil dash light turned on about 2 months ago, last time i drove it, I Did a few Mods on downtime. I installed a oil cooler, F-body Rad, Electric Fan, sparkplugs and wire, Red Top injectors(they were free) Put everything back, now it wont stay on, dies out after 30secs. I have no scan tool (sorry) I took out the O2 it was Carb up big time. After the O2 was switched out,It ran real smooth(30secs) then Dies out. Along with that another problem, I look through the valve cover hole, no oil is moving at higher or low RPM. Is this a bad Oil pump?? i wanted some feedback on getting a high vol oil pump, should i get a stock replacement or upgrade or is this even the problem. Not much details other then, i dont see oil moving in the valve cover, my Electric oil pressure reads low. I uses a oil cooler sandwich adaptor.
Few more items I have done,New Fuel filter, V-power plugs(stock gap), taylor thunder wires,MAF,coil, IAC, TPS sensors are good worked fine before all this.
