monkeyy337
- Aug 27, 2007
I finally got the high volume oil pump gear out of the motor but when I removed the oil pump cover plate the idler gear fell out and I didn't see which way the gear was facing in the pump. There is a small square (I don't know how else to explain it) on one side of the gear flat side surface and I don't know if it should face the engine side (top) or the bottom side (oil filter) direction or if it matters. I also have no idea why the square is machine into the gear or what its function is. The motor is a 231 Buick V6. Thanks for any info.
