Oil pump pick up?
SS/GN
I see 2 different oil pump pick ups ! Does it matter if you use the one with the plate on the bottom or not?
Thanks in advance
If you use the mellings 20IS, check to see if there is a big open hole under the center metal piece, some have it and some don't. The sealed power has a complete screen but bigger mesh they can pass the small stuff. I would, if possible clean and reuse the factory one. None of them are perfect, pick you poison.
