- Feb 18, 2006
Worked on a car with oil pressure issue unknown to the owner. Oil would take 30-40 seconds to build pressure on a cold start. Warm starts not much better. Crack the oil filter and the oil that came out was full of bubbles. Has to be sucking air or is being restricted.
Thought for sure I found the problem when I discovered the RJC oil pan was smashed. The pan was prolly against the pick up. So i pull the pan and straighten it out. Reinstalled and started the engine. Same as before. Oil pressure took forever to come up. At this point my mind is going in 10 different directions.
Had the oil pan and front cover off 3 times trying to find the issue. Motor was literally brand new inside. I spent several hours inspecting and going over possibilities to no avail. I was honestly ready to give up on this one.
The motor has a RJC girdle and a oil pick up extension all of which look like new. Removed the pick up and extension several times as well. Nothing was obvious. Thinking maybe the block was cracked, I even went as far as to pull a vacuum on the oil circuit from the pan. Rock solid. I was at a loss..
I started to look closely at the pick up and extension and discovered a small nick in the side where bolt hole is. Like it was hitting something. Sure enough it was hitting the girdle ever so slightly and keeping it from sealing against the block. I had to clearance the extension quite a bit to give enough room. Put it back together and blamo! Problem solved!
This one kicked my ass!
What kills me more is the owner never even knew about the problem.
