Yankee John
- Sep 17, 2008
Is there an easy way to replace the pcv valve grommet while it is in the car? It looks like it is going to be a bugger!!!
Thanks!
John
Thanks!
John
SignUp Now!Is something wrong with it??
Yes- I put in a new PCV valve and the grommet doesn't hold it in tight.
John
If it seems to be dry rotted, don't bother. It's going to end up in the valley pan.
I regret not doing mine on the bench. I just put one in and the damn pcv doesn't fit. Lesson learned for the next one lolNo big deal, in the very early years I had 2 grommets pushed into the intake when installing them. When I pulled the engine after a few years, they both were resting at the rear of the valley pan!
In recent years a big screw driver and some WD-40 cured my issue, and installing about 100 of them on the bench has been very helpful.![]()
