Turbo Keith
TURBO KEITH
- Sep 16, 2015
So I'm doing some general maintenance on our new car and was changing out old vacuum lines SO when I got to the pcv and removing the grommet it come out in several pieces . I started to replace the grommet and had absolutely no luck , I found I have to order one from Kirbans for the correct size . But when I looked at our other car I found I had the pvc capped off at the valve and the vac line going to the vac block . So my question is do we have the pcv valve working or can it just be capped off ? First I have to get the grommet installed and I can see that is not gonna be any fun . Thanks Keith
