Originally posted by KendallF
By peak and hold I assume you mean low impedance injectors. Peak and hold is the name given to the driver ICs for low impedance injectors (they open the injector with a high "peak" current and then drop to a "hold" current).
The answer: none of the above. I am unaware of any GM port EFI application that used low impedance injectors..
