87we410877
- Apr 5, 2005
If the competition kit is like some of the other kits I've seen, then it comes over length. So basically you cut it down to fit your particular application. The CE kit could be made to weld to the frame or weld to plates on the body. It all just depends on how you choose to install it. But to be NHRA legal, in a full frame car, the roll bar / roll cage has to attach to the frame.
Per NHRA Rule Book "All cars with an OEM frame must have roll cage welded to frame." They don't care weather it is a custom bent cage, or a manufactures kit.
Hope this clears things up for you.
Scott
How often if ever, do they actually check if its welded to the frame? I dont want to cut holes in my floor.
