SignUp Now!Well, you won't want to hear this but I really doubt ANY auto parts store carries it. Kirban Performance has them mail order.
It just isn't a common enough part for auto parts shops to stock.
Autozone does show it on their website, though.
Cardone Reman/Brake Power Booster
For your 1987 Buick Regal 3.8L SFI OHV Turbo 6cyl Part Number: 52-9702ACC
(edit: that can't be right. $309????)
I wonder what other cars have a Powermaster systems... and maybe one could be found in a junkyard?
Hello, this is my first post.
I just discovered that my '87 GN's (33k miles) brakes aren't acting right. The brake light flashes upon application and the boost appears to be weak, absent or sporadic (I nearly hit the car in front of me the first time).
I gather that I should use the GM diagnostics posted here to check by repeatedly applying the brakes with the ignition off, then on (I have the GM service manual, but it fills about two cartons), to see how/if the booster motor runs. But I thought that the motor I heard running when the ignition was first turned on was the fuel pump. Should I charge the fuel system first, then turn off the ignition and apply the brakes to deplete the accumulator?
My main question is, is it safe to drive the car until I get this resolved, even though I may have to stand on the brakes?
If it ends up being the accumulator, is my best option the replacement from Kirban?
(I had no idea that this was a problem with these cars; I haven't had my GN on the road in 6 years. If this is a common problem, would not running the car for an extended period have anything to do with it?).
Thanks.
Jack
Thanks.
Jack
It took only a few minutes to change out the accumulator, and normal braking operation has been restored (previously, it was stopping like a Toyota).
The car has only 32,000 miles on it, so I should be okay for a while.
I also had to replace the battery (the third one in 23 years), the hood struts, the front tires (the original rubber on this car wore like a pencil eraser) and recharge the A/C.
