Polished Stock Valve Covers, RJC Valve Cover Extensions. Etc
GNut
An absolutely beautiful set of show quality polished stock valve covers. Pass. side cover has NO HOLE in the front (no leaky breather!!). Trimmed in Red, they can be easily re-trimmed in any color. $150 shipped.
A set of RJC valve cover extensions for roller rocker setups. These were installed on the above valve covers but motor was never run so basically they are brand new. $75 shipped
I'll be going through boxes of stuff I have stuffed away so stay tuned for more goodies!
I had a question, how does the passenger side cover have no hole in the front of it, did you weld it with a piece of metal shut?? Thanks
Directly from the RJC website:
These were designed to allow the use of all types of roller rockers with the stock valve covers. They can be used with stock and after market heads.
Made from billet 6061-t6 air craft quality aluminum. The outer and inner perimeter is cut using a state of the art water jet cut machine. The mounting holes are CNC machined.
They are 3/8 of an inch thick.
