1badbuford
- Jan 27, 2013
I recently bought a 87 Turbo T, and after getting the car here, I took it for a spin around the block.
It pops at WOT with about 16 pounds of boost. I thought I knew what was wrong, I replaced the coil pack, module, <(from NOS 4GN) spark plugs (autolite 23's gapped at 33), wires, and put a known to be good stock MAF meter on the car. Would a bad MAP sensor cause it to do this? Or would bad gas cause this? I put about 8 gallons in the tank, it had about 1/4 tank of unknown age and condition gas in it when i got the car. Has anyone else ever been through this with bad gas? When I pulled the plugs it had autolite 25's in it and they were all fuel fouled, which would have indicated the parts that I changed. The fuel injectors have a green stripe at the top third of the injectors, and I believe they are 009's. The guy I bought it from says they are 50 pound bosch injectors and Red Armstrong chip. I am also considering changing the chip on the idea that maybe he thought they were 50's and are actually much smaller 009's thus it may have the wrong chip in it. The grounds looked to be good on the back of the heads when I pulled the coil and module. I guess I need to also get a fuel pressure gauge that i can see when its popping. I know with all the guys on here, someone should be able to help. Sorry for the long winded Post... thanks.
