SignUp Now!Based upon the engines we have done, a max port job on a set of GN-1 heads would double the HP from an out-of-the-box set.
HP is all about airflow, and max ported GN-1's have gone into the 8's.![]()
Nick, can you give an example when you say double HP. Are you saying that if my current build is pushing 600 WHP it can go to 1200 WHP. My off-the-shelf GN1 heads are on there way from Champion....so should I get them ported? My build will be a 249 CID with forged internals, DLS cam, etc.
I think what Nick is saying.. If you gain 40 horse out of box, you can get 80 with port work. Nick, please correct me if I'm wrong. Depending on other factors ie. cam, turbo, etc. You might get more. My two cents. Phil.
Also, the stock headers are smaller than the exhaust head ports on the unported GN1's. I would say if you have GN1's also get bigger headers since that is the next bottleneck that I'm seeing, if going max performance. I blew a header gasket (I forgot to tighten the nuts) the other week and noticed the size difference on my stock headers on the GN1's around the gasket imprints, it was a couple 16ths, almost an 1/8th of material easily I was giving up by using stock headers.
That makes sense. I have also read on here that more flow in the heads does not always equate to more HP.
Anyone have flow numbers for ported aluminum GN1's (By champion) vs cast aluminum GN1's?
