As I'm getting back into TB's, I bought the Caspers Pos and Neg battery connections. Before I go about installing them, I've looked for pics and/or threads that would provide guidance to no avail
. I realize that this is not a difficult install, but I would like to do it right and ensure it is correct. What I'm looking for assistance on is the following:
1. Ground to the turbo hanger. Does anyone have a picture that I can follow to determine where to ground? The current setup, which is bad and the way the car came, has the ground to the heat shield support (stock turbo)...the result being that the insulation is melting away. Pic anyone?
2. Pos to Alternator. Is the lenght of the cable long enough to follow the current path which looks to go under the engine or is it to be installed through a different path? Does anyone have a pic
3. Pos to Starter. I've been unable to locate the starter visually (still a noob) and it would appear that the cable is not long enough. Which means I'm not looking at the install correctly. Again, any pic or site for guidance.
If there's a thread or site with pics of the install, that would be great. Many thanks.
Chris
Chris
