I did some maintenance this winter and was trying to find a oil leak that i have been chasing for a while now. I thought it was the valve covers, then the rear main seal, etc. My starter would have oil dripping down it and the oil drips would wind up directly in the center of the flywheel cover. Well, after much work here and there, and changing gaskets, etc. I found it was leaking from the my valve covers. I have the GN1 covers, with the push in style Metco Breathers, on the angled push in style adapters.
I thought about making a baffling solution in the valve cover, but found 1 or 2 small threads here mentioning gasket baffles.
I found some in the store and wanted to share them since the leaking valve covers is an ongoing topic on here and there are no good threads in here about them that "I" have personally found.
Mr. Gasket sells these:
Baffled Grommets - P/N 5425
They can be picked up from the local O'Reillys for like $3 for a set of 2.
