kevin koch
- Oct 15, 2003
When autocrossing an '87 GN for the first time the engine would die at least once per run. No coughing or sputtering just a clean cut off. Usually happened during cornering or going into a corner. Always restarted right away with no problem. Also no problems during normal street driving. Could this be torque converter clutch solenoid not disengaging when required?? Has anyone else experienced similar?? Thanks
