SignUp Now!If you can lock up the wheels, there is no need for more braking either through pressure assist or mechanical friction. That's always been my test.
Dave I do agree hydroboost is complex when doing a change-over, but stopping power is the mechanical function of many items in the brake system including tires, and using a different manner of powered assist does not give better stopping.![]()
Apparently these Turbo 6's will make enough torque that they can overcome the braking pressure put on the rear drums (with vacuum brakes) therefore allowing most cars to push through the lights at only a few lbs of boost. Some people put the longer shoes on the rear helping their cars performance.....
They will at some point.... yes..... There is a difference in launching a car at 3 psi vs launching a car at 13 psi no? Most threads I see with people with vacuum conversions wanting to hold more boost are complaining they can't hold any boost or just a couple psi boost before it pushes through the lights.They can do that no matter what system you use.
What the hell does the type of power assist have to do with holding boost at the line?
Once the pedal is pressed, the power assist job is done.
At that point it is a MECHANICAL problem, and has nothing to do with the type of assist.
I really try to avoid pissing contests based upon opinions rather than facts or personal experience, so I will just bow out of this thread, and let you spread your beliefs.
I do have a BSME in mechanical engineering, but I have learned to overcome that handicap in the real world.![]()
I guess , what my question was , is, my power master is going south , should I get it rebuilt ? switch to Vaccum ? or to hydra boost ? I drive my on the street , etc ,
I had no idea it would start a pissing match ?
Just want to throw this out there. I have 87 S10 wheel cylinders and shoes on my car as well a hydra-boost. In my driveway, with foot brake, I can hold 14# of boost like nothing and no tire spin. With hydra-boost, 90% of the turbo regal owners issues are related to vacuum. If you bullet proof your vacuum and maintain your brake system, then you are set!!
Nick Micale said:An overlooked reason for building boost or not, is an item your car has that ANY car needs to build boost at the line, and that is the proper converter loose enough, which you DO have.
I have built MANY TR race cars over 25 years, and this "not building boost at the line because of my ****** brake assist" is complete bull shit.
If your combination is NOT compatible and proper, your launch will suffer the most.
I have worked on lots of record setting turbo Buicks with various brake systems, and all of them work when the combination is proper.
The guys with one car they built put out their bull shit opinion that so-and-so is the BEST because they think it works for them, and that is the BEST?
Yes, I do get fed up with "experts" telling everyone how to build a race car when they have only opinions with no actual track experience to measure different methods and parts.
No wonder so many experienced and knowledgable tech guys no longer choose to post as some arrogant ass-clown with "internet" keyboard knowledge can do it better.![]()
Somehow I thing that tyrade was pointed at me, and possibly a few others, so I'll refrain from adding any expertese in such matters.
Reliability of the different assist systems is another matter!![]()
