Thanks for your opinion man !! I think so tooI don't trust them. All it supposedly equalizes air in each cylinder but it does so by restricting air to some cylinders...
Claude.![]()
SignUp Now!Thanks for your opinion man !! I think so tooI don't trust them. All it supposedly equalizes air in each cylinder but it does so by restricting air to some cylinders...
Claude.![]()
Thanks for not having a smart mouth like a child !!!!I don't trust these. They supposedly equalize air in each cylinder but not by improving air flow, but rather by restricting air to some cylinders. Anyway you look at it, it doesn't make more air come into the engine if it has to pass through the small holes in the plate.
Claude.![]()
Why reply if you think it's been beat to death? Just pass on and not reply? You bored? Or just practicing your typing ?To look on the flip side....can you really say the thing is restrictive that it is if the openings on the plate all together are the same size as the inlet into the plenum. Once again been beat to death
Any time you make air pass through a change in cross-section, such as from the plenum through the power plate, a pressure drop occurs. Basic fluid mechanics. If somebody tapped their plenum and intake manifold with a differential pressure sensor, they could measure the exact pressure drop.
Does the benefit of more equal airflow to the cylinders outweigh the pressure drop? Well, I think so, since I'm running one on my car. 25 psi with 100 octane and no-so-rich fueling is a bit dicey, and I believe the power plate helped me get there.
Sent from my SCH-I535 using Turbo Buick
I have found they look more even.i shoot methanol and nitrous through mine no issues with the plate.
Any time you make air pass through a change in cross-section, such as from the plenum through the power plate, a pressure drop occurs. Basic fluid mechanics. If somebody tapped their plenum and intake manifold with a differential pressure sensor, they could measure the exact pressure drop.........
These cars leaned the back 2 cylinders from the factory. The whole idea is to make all the cylinders even. Richard Clark tested the plate and it does exactlyI don't trust these. They supposedly equalize air in each cylinder but not by improving air flow, but rather by restricting air to some cylinders. Anyway you look at it, it doesn't make more air come into the engine if it has to pass through the small holes in the plate.
Claude.![]()
