- Jan 18, 2011
x2.How is the spooled compared to a dbb? Also is there an oil feed line provision? Can you post pic of exhaust wheel?
SignUp Now!x2.How is the spooled compared to a dbb? Also is there an oil feed line provision? Can you post pic of exhaust wheel?
LOL Yep that's what I was getting at!You mean like this???
When you say your car are you talking about the 4.1? If so,have you had it up to 28 on the 4.1?I have a version of the BW on my car right now. Here is what I can say. At low boost (17-22) don't expect much. At higher boost like 28+ it's a monster. There is no turbine housing for a Buick right now a few Garrett and PTE housings have been machined. We are looking at doing a turbine housing but these turbos are more costly than other brands, not billet or ball bearing so we are trying to determine if the market is there to justify the cost. The PTE turbos are proven performers with a low failure rate overall and priced pretty well. IMO turbonetics is not an option maybe Comp but I have not had enough test data to be sure. Right now from a performance stand point only the BW will compete and the BW EFR line is awesome but I doubt many Buick guys will spend EFR money. In the end guys if we really want to move forward with technology and choices then we really need to look a 4 bolt turbos and external gates. That will provide a quantum leap in performance and value. Maybe a 3 to 4 bolt adapter and a down pipe to fit. Weld a gate on the header and go fast
Now wait just a minute. Everyone knows that the factory 4.1 blocks will not handle that much boost.I have had it to 30 on E85 which resulted in giant clouds of tire smoke
There are a few guys who have spent EFR $$$$ but they are far and few between. Garrett is even more outrageous with their GTX line. The 3 bolt is too turbine limited to get the most out of new compressor tech with traditional wastegating.I have a version of the BW on my car right now. Here is what I can say. At low boost (17-22) don't expect much. At higher boost like 28+ it's a monster. There is no turbine housing for a Buick right now a few Garrett and PTE housings have been machined. We are looking at doing a turbine housing but these turbos are more costly than other brands, not billet or ball bearing so we are trying to determine if the market is there to justify the cost. The PTE turbos are proven performers with a low failure rate overall and priced pretty well. IMO turbonetics is not an option maybe Comp but I have not had enough test data to be sure. Right now from a performance stand point only the BW will compete and the BW EFR line is awesome but I doubt many Buick guys will spend EFR money. In the end guys if we really want to move forward with technology and choices then we really need to look a 4 bolt turbos and external gates. That will provide a quantum leap in performance and value. Maybe a 3 to 4 bolt adapter and a down pipe to fit. Weld a gate on the header and go fast
Do you think it would be a good idea for me to install an 85 a/r turbine housing on my 6776 since I'm 40 cu. in. larger and 9 to 1 compression ratio? I wouldn't want it to spool any slower than it did on my 7.9 to 1 235.There are a few guys who have spent EFR $$$$ but they are far and few between. Garrett is even more outrageous with their GTX line. The 3 bolt is too turbine limited to get the most out of new compressor tech with traditional wastegating.
no one told my "crappy" 484 block it could not take it. Seems pretty happy so far. I am getting to build Version 2.0 which will be a long rod stroker and see what we can do with thatNow wait just a minute. Everyone knows that the factory 4.1 blocks will not handle that much boost.![]()
The 4 bolt EFR with the flapper valve in the turbine housing might be a possible bolt on fix but it appears that when it is clocked properly the actuator will not fitThere are a few guys who have spent EFR $$$$ but they are far and few between. Garrett is even more outrageous with their GTX line. The 3 bolt is too turbine limited to get the most out of new compressor tech with traditional wastegating.
The t4 with the turbosmart plumbed upstream is the way to roll for sureThe 4 bolt EFR with the flapper valve in the turbine housing might be a possible bolt on fix but it appears that when it is clocked properly the actuator will not fit![]()
Pm me this question. I don't want to get too far off topic on this thread. It's more about whether or not you want to be able to run the turbine/ compressor at it's max. It won't matter much if you're not looking to run it all inDo you think it would be a good idea for me to install an 85 a/r turbine housing on my 6776 since I'm 40 cu. in. larger and 9 to 1 compression ratio? I wouldn't want it to spool any slower than it did on my 7.9 to 1 235.
