GNONYX
- Oct 16, 2009
How many mileage is on the car?
SignUp Now!All I can do is try. What gets me there are some pretty reputable guys in this thread telling people it's ok to dry crank your motor. Worse than that unplug the coil and module so it won't start resulting in even more dry cranking. NOT SMART!
It's pure common sense. Never dry crank a motor to get oil pressure.
Rick
Sorry to take so long. I don't log-in here everyday.
The car has 27,000 original miles on the odometer, and as per CarFax and AutoCheck, seems to be appropriate. Long story behind it, but I have great hope for the car. I am going to try and take some videos and photos, and likely create a blog/diary of my time with the car. I am going to pull the headliner cardboard down (carefully, no broken clips!!) to get at the build sheet. The options code sticker on the trunk lid is perfect (as is the trunk surprisingly). It will be a slow process as I must get approval of the other half of my Budget Committee for any expenses...happy wife...happy life!
We had a downsizing a couple years back and I was forced to layoff or dismiss the other half of the budget committee.
I also lost 135 lbs in the process. (Her)
However, with the reduction in expenses for curtains, pillows and general non-essential kitchen crap, (the only essential kitchen item is a pizza box) - that left a considerable amount of new, discretionary spending to occur for Buick essentials.
I found it to be a win-win.
Would like to hear how this one works out. please keep us posted!Your journey sounds just like mine. Car sitting outside for 3 years, no cover, no start. I was wondering the same thing about the dry start. My new purchase has 58k from the original owner. I think I might just go with the orange wire disconnect after replacing all the fluids and adding the ZDP stuff to the oil. Still digesting all these replies to your original question. Great thread!
Just spoke to the original owner and he used Mobil 1 since new and per this thread that oil disapates so it looks like I will be pre-oiling before first start.Would like to hear how this one works out. please keep us posted!
Probably been covered but am too lazy to read all prior posts...i imagine its relative to the amount of spring pressure you have at the cam more than anything...ive seen 980s come out, after only a couple seasons, at 50-55lbsI see you are from Canada. My GN sits a lot in the winter. I found heating the oil in the oil pan before starting, it helps the oil move much faster to the valve train. I run Brad Penn's 10w-30. I like the ZDDP
My car sat without being turned over for almost three years. We replaced the tank and fuel pump and fired it up. That was with 23k original miles. Car now has 91k and runs great. I did put bearings in it at about 70k but that was from a misfire that bent all 6 rods. The bearings on #1 and #4 looked great still as did the cam bearings. Just my experience. I'm in no way suggesting that pre-oiling is bad, but it may not always be needed. Experiment at your own risk.
What was wrong woth the gas tank that you replaced it?
Rusty. Kept taking out pumps so eventually they just let the car sit.
