Project V6 Firebird
Pulling the axles to install ARP studs and gonna install the ta performance rear end cover while I'm at it.
Also, rear end fluid should not be allowed to stew overnight in the garage in your oil catch pan. It wasn't so bad when I popped it open but once left to the air it got worse. Good thing it didn't look like chocolate milk though. I'm just doing a series of things to the car while also doing the manual trans swap.
More stuff today...
Roads? Where we're going, we don't need roads...
Powerbond SFI balancer. It's been waiting a while to go in, this was the best opportunity to do it during the swap!
You going to try and make it to the TX leg of the power tour this year? It ends in Arlington if you feel like joining in.:)
Hubs are all off. Gonna take it all to my dad's shop on Saturday morning, get the ARP studs pressed in. Put it all back on and then full steam ahead on the trans swap!
It'd be cool, but I'll be working, in school and also helping my wife with our new baby girl.
Anywho, more "progress..."
Pulled all of the carpet out of the car...Made $3.15 out of it in loose change. Previous owner had to have left their change in the little cubby hole in the console and not in the change holder where it should be. I guess that solves the odd rattles I had at times. Pulled the brake pedal assembly as well.
Ground on the block a little, but not enough as it was getting late. I have to shorten the driver side dowel on the block to clear the mal-wood adapter. Was about 1mm shy. Gonna go to harbor freight and buy a sawzal and go to town on the trans tunnel Monday night!
Debating on sending my steering rack in to turn one, mine is leaking and helping coat the bottom of my engine block and chassis in a nice, glossy film of CRAP!
Come on now. You're in Lubbock and you could show up very late Friday and drive back on Sunday.;) Not like you're in NYC after all.:p
Tick clutch master cylinder is installed. Gotta wire up the pedals and all that fun stuff probably on Tuesday. Once I opened up the bolt holes a little more, the cylinder bolted in perfectly! Zip tied the reservoir to the mount for now, and I still need to get under the car and attach the line to the master. I'm gonna need to reroute some wiring after all is said and done. I don't like the spot where I routed my wideband wires, so I'm going to look into running that stuff through another spot instead of the grommet right below the driver's seat. Just looks trashy to me from under the car.
Front suspension is bolted on, looking great! I love working with brand new parts, a whole lot less cleanup involved :lol:
Finally got my 3/4" spacer for my hydraulic throwout bearing (yes, 3/4"). Luckily RAM had one that they use for retrofits for the T-56 on other cars. It's the size I needed as the flywheel and clutch that doesn't stick out as far from the block as on an LSX + the 1/4" adapter was enough to skew things enough to where I needed to run a spacer as a shim just wouldn't work.
I'll put in the trans, then bolt up the rear suspension components. Makes it easier for me to do it that way so I can fit the driveshaft on a little easier.
Then I gotta put the longtubes back on and put the interior pieces in :)
Progress is being made, I'm a wiring newb so some things like wiring in the reverse lockout solenoid has been a challenge. I'm wiring it into the brake as I didn't feel like trying to figure out the rats nest of the pcm pinouts and couldn't get anything reliable off the old auto pigtail. I've run a grommet through the trans tunnel so I can run my wires cleanly through there and under the console and dash. I'm excited to get things finished and they look to be getting really close.
Especially after this:
I had to modify my T-56 crossmember. It takes a lot of balls/faith/stupidity to modify a brand spanking new crossmember for 1/2" of clearance needed because of the spacer. With a stock crossmember, there's probably enough tolerances in the manufacturing process that you might be able to bolt it up lol! Took it to a welder that used to work for the USAF, damned good guy, has a nice little piece of stainless steel welded to aluminum to showcase some of his work. Got extensions welded on, then had to go to a friend's place that had a drill press and a bridge port mill that had enough reach to work over the plate.
Took it home, test fit (LIKE A GLOVE! MEH MEH MEH!) and now the paint is drying.
I'll try and post here and there, and a writeup will follow at some point after the car is on the road.
So for the first time since April 13, the Firebird went for a drive. Fired it up yesterday after doing the T-56 swap, took a lot longer to do than anticipated, but it is done!
Need to re-tune it and do some final adjustments along with putting the rest of the interior back in the car but I am happy to see the car running.
Got a new camera, trying it out and getting the feel of using something a little more potent than my kodak easyshare :lol: Got a Olympus E-420 off ebay with a lot of gear for a good price, only had it a few days, so go easy.
No tripod used, light was getting low right around sunset when I found this spot. Went driving around, looking for a place to take pictures where I wouldn't have a high likelihood of getting robbed, mugged, raped or stabbed with a spork.
Yes, the car needs tint, paint, and a V8, plate covered, ooh and trashy naked lady mudflaps :D
Anybody have any good tips with using a DSLR camera?
