What A/F ratio do you guys target at full boost when you are running methanol injection?
I have noticed that I can go quite a bit leaner than normal with alky injection, but I'm still a little confused about how the methanol impacts the WB 02 readings.
Normal gas is most chemically efficient at 14.7:1
Methanol is most efficient at something like 7:1
Most people generally target 12:1 or lower on high boost applications with just gasoline to get the most out of it. What should the target be with a mix of the two?
I’m assuming the typical 02 sensor has to be calibrated with a specific fuel in mind. It reads oxygen content in the exhaust stream and then the controller determines what the original a/f was based on this reading and the stioch numbers for the fuel. In other words, It seems like the controller must be calibrated for a specific fuel.
It seems to me that the methanol would make the WB read leaner even though the actual a/f ratio was richer. Am I missing something?
