1KWIKSIX
- Sep 29, 2007
SignUp Now!Here you go, if you have a fitting on the tank for the spitter #3 hose you don’t need the tee on the return hose #4Does anyone have a quick sketch or explanation for how all these lines run between these components for those of us making the jump to hydroboost and the PSC reservoir?
Hydroboost
PSC Reservoir with no "T"
Power Steering Pump
I'm about to ditch my Powermaster.
Wow! Perfect. Thank you.Here you go, if you have a fitting on the tank for the spitter #3 hose you don’t need the tee on the return hose #4Does anyone have a quick sketch or explanation for how all these lines run between these components for those of us making the jump to hydroboost and the PSC reservoir?
Hydroboost
Power Steering Pump
I have and will continue to consider that. It was a cost factor at the time but I'm learning that saving a few bucks on something for these cars usually just ends up with me doing the job a second time.Unless I am mistaken you have a HB unit with no accumulator... might want to rethink that. If you are going to drive this on the street the unit with an accumulator is good back up if you throw the belt. Just something to consider.
I think your diagram is correct. I got my PSC today. That thing is pretty impressive. Google Fragola fittings. I have a fragola dealer near me. Going to show him the PSC tomorrow and will probably just let him install the new reservoir next week. Will need new hoses cut to length when I eliminate the "T".So, I drew this routing as sometimes I just need to see it this simply. Do I have this correct?
Also, here is everything I have ready to go. It sounds like some of these push on hose and clamp ends from the stock setup (gravity feed from PSC to pump and steering box to PSC) are going to need some push-in-to-AN fittings in order to mate with the PSC.
Anything else I'm missing?
The stock 84 and early 85 tr as well as the diesels run like that. Ive run this setup for years on my 87. I also have several trucks with the setup with the reservoir. Never had a problem with the 84 I had or the 87, but have thrown a belt on our suburban(tensioner broke) and that reserve ain't much. You might get a pump or two of power assist. It isn't like you loose brakes, you just don't have power brakes. When was the last time you threw a serpentine belt?Unless I am mistaken you have a HB unit with no accumulator... might want to rethink that. If you are going to drive this on the street the unit with an accumulator is good back up if you throw the belt. Just something to consider.
Got mine installed yesterday. The shop didn't use the Chinese fittings that came with the reservoir. It's Fragola all the way. Happy with the install but the brake pedal still is a little slow to come up.
From my brief experience with my own HydroBoost install, the brake pedal will be slower than my previous vacuum system.
How do you like your HydroBoost system versus the vacuum?
Very little driving time as I'm in the throws of fixing a power steering fluid leak. However seat of the pants feel is much much better braking!
Tight in there. I'll be finishing mine up this weekend. Great to see this pic.Got mine installed yesterday. The shop didn't use the Chinese fittings that came with the reservoir. It's Fragola all the way. Happy with the install but the brake pedal still is a little slow to come up.
