- Mar 1, 2005
I got a 350 trans with a PTC converter for a V6 if anybody is interested in the whole combo PM me!
SignUp Now!I went to test and tune today to try out my new 10", 2800 PTC tc. It worked well but did not give me the mph I got when I locked my PTS 9-11 tc. The best run I had today was 7.154 @ 96.83 with a 1.608 60' and I did not lock the tc. With my PTS 9-11 I ran 7.1x @ 99 mph when I locked it but only 94.5 mph when I did not lock it (same et). So it looks like I gained 2+ mph with the PTC over the 9-11 when not locked but I lost 2+ mph over the locked 9-11.
I had 600 rpm drop at gear shifts, the same as I did with the 9-11 when unlocked. When locked, the 9-11 would drop 1,000 rpm.
Attached is a screen shot at '0' mph. It shows the tc stalls a lot higher than 2800 and I could really build boost off the foot brake.
You are correct about the 1-2 shift being higher with the PTC. It shifts at 26 mph while the 9-11 shifted around 12 mph. I don't have any 1/4 mile tracks nearby.
Why is the stall so much higher than 2800?
I have 27" (255-60/15) MT ET Street drag radials.
1-2 shift was at 5460 and went to 4890. 2-3 shift was at 5522 and went to 4842.
Attached is another screen shot of same run.
I think you need some 28" tall tires to get that converter lugging down. I know when I take my 26" tires off and put my 28" with my weld wheels I can feel the engine staying in the powerband longer. But I dont have any track times yet with my 2800 10" so dont take my word as gospel.:redface:
I will be going in October....
Dusty--The tc seems fine as is. I really like how it drives on the street, especially at downshift. :biggrin: I hope to return to the track Thursday night for more test and tune.
Will the car respond better if the shift point is 200 rpm higher? Can I get there by removing weight from the governor? Thanks.
You will almost always mph higher with a locked converter. He picked up a lot of efficiency unlocked with his 10" vs. the 9-11. Therefore the car can stay in 1st and 2nd longer and benefit from the better coupling efficiency the converter has vs the 9-11. Thats why he went faster with the unlocked 10" vs the locked 9-11. Id like to see the mph gain on a 5 disc vig vs my NL 9.5" PTC. I bet it wouldnt be more than 1 mph. Im slipping about 4.5% at 135mph. Im almost positive it would not e.t. as well with a 5 disc since they suck when unlocked. Giving up way too much in 1st where the car isnt moving fast yet. The 1-2 shift occurs at about 50 mph and the 2-3 is at about 87 mph in the car in my sig. This really helps the cars e.t.Two things
It seemed like you compared the unlocked PTC to the locked 9-11.
What psi are you running as that can affect shift rpm a little.
I had Jimmy trim a touch out of my governor and it went up about 150rpm so you can do small amounts if you are concerned.
