Mike T
- May 3, 2013
The double ones are probably painted like this?
At least one was painted I'll check tomorrow
Leaning towards this one because of the way a couple of the veins are positioned.Or did the slide crater and take the rotor?
Have taken 2 built transmissions apart for comparison and both appear to have the same setup. I have not taken the original stock trans apart so no idea how thick the oem slide is.a slide that is more "robust" than a stock seven vane slide. Any pix to see the difference?
Have it written down but I believe around 270what psi were you running at full tv?
It was a PTC 9.5 that I bought new.the converter with the cracked hub, was it checked out for concentricity before install?
