So I'll hold off from Mellissa's car seeing i'm only 4 tenths away
Scot w.
I was thrilled to finally see the car run in person... actually ran against it in your 10.0 pass.
Great gob Melissa, Dan & Russ!
Dan's definitely not lying with the street car stuff... I was at the front gate this morning and Dan and Melissa came driving in... probably one of the quietest, unassuming looking TR's there.
Russ... thanks for letting me bug you on Friday... I ended up running a couple of 12.20's.
Eric
:biggrin: yeah it is pretty funny! I've got ALOT of room left in boost to be able to pick up 4 tenths! And you know that! You should set her car up to handle on a auto-x course THEN see if you can still run those numbers!! I've said before and i'll say it again "I'M GETTING THERE!" and the last time to the local track was a 7.0 @ 100 the next time was 6.76 @ 104. on 24lbs Thats a pretty good jump if you ask me! I'm sorry Grumpy, Don't be confused! I was just saying what it will take to run your times. kinda like a goal for me! :biggrin: Your my hero!! :biggrin:hahahahahahaha...only .4 tenths away !!!! now that is funny :biggrin: OR is this a woulda, coulda, shoulda
That car is flying. Are you still on the single in tank? I doubt any brand X'rs will believe those numbers. A lot of TR guys wouldnt even believe them if they didnt check this board. Nice work.
Whats the plan now Dan? You guys gonna haul out the cage and get a 10pt, or just leave it at this level? Congrats again, I know you guys busted your arse to get her there. The beauty is there is more left. Very impressive.
That's some pretty impressive stuff Grump and Melissa!!!!!!!
Care to share any trade secrets, like Tire size and pressure, launch and WOT boost and gears?
Again, congrats!!!!!
Grumpy, I think you, Melissa and Russ are gonna be the cause of a lot of broken motors.
Id believe it. Theres no doubt our throwing in a lot of methanol. Id estimate that you are feeding 175-200hp with the methanol itself.Single in tank 340. I won't say anything on the tune up except...... You'd be shocked if you knew and you probably wouldn't believe that either.....
You mean you had to tune that car? I thought the magic camshaft did it. Ok so what are you bringing to Reynolds?
