Very carefully...........How do you milk a badger?![]()
SignUp Now!Very carefully...........How do you milk a badger?![]()
VERY carefully! (x2)How do you milk a badger?![]()
Dang... before my dad died earlier this year he had purchased a Snow performance kit for his 87 in October, but didn't get around to installing it before he passed.
It is just sitting in a box, along with another package that has a couple custom made braided hoses. He gave me his GN and warned me to leave the boost at no higher than 14-15 psi unless I ran 116 or installed the Snow unit..............................
We have a few local GN's using that GN kit and it is a simple, trouble-free system that will do just what you want. Installation is very easy as we just did one yesterday, and can get you pics if wanted.
Any time you add an alky injection kit you MUST be sure that you have ample fuel delivery since when you up the HP level, the engine requires more fuel along with the alky. You should also obtain a new computer chip to work with alky injection.
This kit will allow you to run about 22 psi boost safely, and this will give you a very "spirited" GN for the street!
If the car was running 26 psi at one time, it was most likely on race gas to keep the engine from any damage.
Try to learn as much as you can about GN's and especially your's, and feel free to contact me if you need more specific info on the Snow kit or any other area of the GN, good luck and enjoy it!
You're correct the chips are labeled with their octane rating. The 108R is a race chip designed for high octane. It appears to be a copy of a Red Armstrong chip because it says Red 108R His labels never looked quite like that.
Nick is correct, the Snow systems are perfectly fine. They're no better nor worse than any of the others. Just a different way to "skin the same cat".
I disagree with the last statement. There are differences in systems. I'm not a commercial, but different systems do have different capabilities. The Snow system will probably be all he needs for his goals and he should use it since he already has it. If the limits are found, then an upgrade is available when the time comes.
Yes an upgrade is available, but I hope it doesn't involve a new short block.
Will a snow kit work? I guess it will. Would I personally use one? HELL NO! Snow performance specifically states that unless you use their overpriced BS boost juice they won't warranty the product.
Your kit has the shitty controller that were only available at the time that unit was bought by your dad. If you do end up using that kit make sure you have a S/M to watch for KR.
He bought the unit late last year. In October. So, is there an updated controller that isn't as "shitty" released between late last year and the present? Does anyone know why he would have also purchased a couple of higher quality hoses to go with it?
Dang! Some of you guys have a REAL issue with that product. Like Macintosh and Windows, Niners and Seahawks or MaryAnn and Ginger.
I don't care about the warranty, I didn't pay anything for it in the first place, but it looks like these things aren't really all that expensive to begin with. Can you run straight methanol in it? I will run whatever works best in the thing, regardless of support, but I will be glad to use up the 8 gallons of stuff that the old timer already bought. Taking my time before install to figure out the car, but if you are me, just looking to get what I can out of this kit, which chip do you use?
I can't use either of the chips I have correct? If there is one that will work properly with the Snow kit I would like to use it.
