I knew it wasnt over for the flat tappet...........
Good work A2000RICH!
I doubt we will see a recovery in the flat tappets reputation but im willing to try again using some of your Lube!
A.j.
send me an address and i will get it on the way
SignUp Now!I knew it wasnt over for the flat tappet...........
A.j.
I wonder why the oil only seems to go bad and not work on my #3e lobe but works on all the other lobes.Literally hundreds of lobes and the only ones to ever wipe was that same lobe
I believe this has been discussed in other threads, but it's my understanding there is actually a pretty well documented manufacturing flaw with the #3 exh. lifter bore in 109 blocks that typically prevents that specific lifter from rotating in the bore like it's supposed to. Apparently, it's very common for the #3 exh. to go first as a result of this manufacturing error.
I'd like some for my build as well A2000Rich. Tell me how much and I'll send the money.
i'm giving out free samples to board members till the final packaging is ready........email me with a request and address
How many ppm of ZDDP should be in a qt of oil? Mobil 1 15-50 has 1200ppm phosphorus and 1300ppm zinc. Not enough?
The regular mobil 1 has 800ppm phos and 900ppm zinc.
I was wondering...the Mobil 1 10-40 racing 4T motorcycle oil has a whooping 1600ppm phos and 1700 zinc.
So the question is how much per qt is enough?
