Ready for another race at Farmington??
Killer 60 ft
hey scott
That was some great #'s what boost was you running out there
i got a best 60ft with my car on street radials with a 1.76 while i was there
Run 1 pump gas/Alky @21 psi of boost on radial T/A's 2 psi launch
60ft 1.856
330ft 5.287
1/8 8.227 @ 83.881 MPH
run 2 pump gas/Alky @ 21 psi of boost on radial T/A 2 psi launch
60ft 1.814
330 5.226
1/8 8.146 @ 84.507 MPH
run3 pump gas /alky @21 psi of boost on radial T/A from a idle
60ft 2.134
330 5.580
1/8 8.463 @ 85.897 MPH
Run 4 pump gas/Alky @21 psi of boost onn radial T/A 5 psi launch The track was hooking!!!!
60ft 1.762
330 5.227
1/8 8.192 @ 83.144 MPH
on my last run i took a friend of mine for a ride with me to show him how to stage the car and how to drag race( his first time out to a dragstrip) so i had about 225 pounds more in the car LOL.
He said that was more fun than a ride on a roller coaster
also for some reason the car just didn't want to respond that well on the top-end with the alky cause i was still getting knock on the top-end with the alky pump speed on setting 8. i think i would have been better off with a mix of race gas but i just wanted to see how it would run on a mild street tune.
__________________
here
Quote; "#'s what boost was you running "
1st pass @ 7.9 was at 21 lbs, rest of the passes were at 22 lbs.
I had a pretty good time but expected to see a little better turnout.. I believe it may have been the threat of rain?? Irregardless I am happy to see Daniel Steele dip into the 6's along with Turk Bates. Tommy Rierson did push a head gasket out but I'm sure he will be back up and running soon. Pat, the crystal ball is still showing a 60-series turbo?!? :D
Mike Banas
87GN
