HighMileage
Albany,NY
- Jul 24, 2010
Got a new set of Metco lower arms. I noticed that the holes for the swaybar are much larger than factory.
I also noticed that the swaybar will accept a 7/16 bolt (5/8 hex) with just a little drilling. ...instead of the metric size. Actually,a 7/16 bolt goes thru one swaybar hole already. Thoughts on going 7/16? They will be grade 8.
One other thing... The factory lower arm bolts fit sloppily in the Metco bushings. My factory bolts are not worn. I would think there would be a zero tolerance between the bushing and the bolt. Otherwise,I'll have to make sure the arm is pushed forward on the bolts before tightening it down. ?
Earl... I know. I over-analyze everything.
