I have had some serious problems with this engine! I had it rebuilt by class one machine in Freeport, Il, who has done all my work in the past. After completing assembly I installed the engine and broke in the cam (a 212/212 unit) the engine made a ton of noise and overheated pretty badly as well. no knocking though. I replaced the radiator but this made no difference. then it blew a head gasket. so I pulled the engine, we dissassembled it and went through it. everything in the bottom end was fine but a couple cam bearings,especially the first one, were chewed up pretty bad. installed a new cam and bearings and gaskets, new crank/rod brgs too, and put it back together. I started it and it sounds exactly the same temp started to skyrocket, so I shut it down- what next???
