rebuilt engine on ebay
I personally wouldn't want it myself because of the 60 overbore. If something happens its rebuild life is over unless you put sleeves in it. Also I thought you got a sg1 block under warranty but I may be wrong on that one
GM warranty motors were NEW. All I have seen around here would get a NEW shortblock and the dealer would used the rest of YOUR parts . .60 over motor I wouldn't go near regardless of who built it :rolleyes:
gm warranty motors were new. All i have seen around here would get a new shortblock and the dealer would used the rest of your parts . .60 over motor i wouldn't go near regardless of who built it :rolleyes:
+1
Maybe I am missing something, but did not see where it stated it was a 0.060" over bore?:confused:
Our Local GM dealers did sell reman 109 engines that did come with a warranty.
The question is does this engine have turbo pistons and crank? :eek:
You cant see the gm tag in the pics so I ask the seller. He sent this to me.
Quote:
Originally Posted by DailyDrifter
One local guy here is putting his motor back together .070 over . Personally I would keep the cylinders as thick as possible.
Quote:
Originally Posted by boostingbuick
I had it sonic check and was told I have enough casting to go that big. Since he was one of the better builder that is around I have no concerns.
Key is to sonic check
my machinist has built one that was .125 over, that went very fast for a long time. but on the other hand, had a stock rebuild for a daily driver .020, and it had a pin hole and leaked coolant, QC on these blocks is truly a joke
FYI there are a few very fast guy's on this board that are .100+
I trust your knowledge and agree with you!
