from the help tab, click the Reflash PL button, choose the PL030 file and click ok, a window should appear showing that the reflash routine has connected to the PL and ask "are you sure", hit enter to continue and reflash.
reflashed successfull but its still not holing connection-then it stops connecting altogether and gives com port error. Can I call you and step thru driver install?
scanmaster now shows 3.0
Got the drivers to try and load and it said my drivers are up to date...so Im ok there.....I watched your video-but this is a black powerlogger I'm using. I will drive car tomorrow and see what the result is..
