Removed A/C box. Now what do i do to cap off my heater ports?
Calia22
So i removed my AC box. I'm just trying to see what other members have done for capping off their heater inlet/outlet. My engine builder put in a -10AN cap on one end, but on the water pump side, what would be the best option? i was thinking tapping and throwing a bolt in it, but i have no clue what size i should tap it with. Any inputs would be greatly appreciated!
-Casey
Ive used epoxy putty with good results. Use a water wet finger go smooth off the inside/ends
So you're saying fill the whole thing, yeah? Just block it with my finger on the bottom side and fill it up?
On the intake, I would just put a pipe plug in the hole. Better yet, if you have a reason for an additional coolant sensor or switch, this is a good spot. I used it for a warning light switch.
On the pump, you can fill it. But If you have someone to do it, would prefer to see it welded. I would put a rubber cap and clamp over it.
If you thread it, be careful. You may split it driving the tapered NPT pug into the hole. It doesn't take much. Just a little bit to tight and "crack".
Tap the water pump with a 3/8 - 18 NPT then put a plug in it from any hardware store. I used a tap and die set from Harbor Freight (p/n 91395). If you put a rubber cap and clamp on it, the turbo will bake it can it won't last a year. Had that happen once but luckily I caught it when my temps started skyrocketing.
The port on the intake is 1/2 NPT for the pipe plug. I like the brass ones with the hex personally.
Here's a shot showing the size of a 1/2 and a 3/8 plug...
The nipple standing up on water pump ...yeah fill it about half way or all the way. Easily drilled out in the future.
