Mikes86Buick
- Aug 11, 2009
I removed the front timing cover to replace the gasket and give it a good cleaning. After the fact i cracked open the repair manual and it said " anytime the cover is removed, pack the oil pump with grease to help it prime". I also just installed a turbo saver system. What do you guys recommend before the first start up? thanks, Mike
