Removing ac/heat question
86SOBTType
I'm currently removing heat and ac.. I got everything out except the heater hoses that run to the radiator.
I've searched on here and Internet and the parts stores couldn't answer my question.. What size are the plugs I need for the radiator holes? So I can thread something in them and plug it?
Or is there a kit?
Thank you!
No heater hose run to the radiator...Perhaps you mean the oil cooler lines.
My bad did not mean radiator.. Meant the lines that run to the motor sorry
Been researching and asking a lot of questions haha
OIC, well the one that goes to the intake is just pipe thread...I don't remember what size but all you need to do is remove the fitting and take it to the store with you...the one to the timing cover is just a slip over hose with a clamp, you can get a rubber cap at most parts stores.
If you use the rubber cap on the water pump be SURE to check it frequently for deterioration. I prefers to tap the ID for a pipe plug. The rubber plugs are just rubber with no fiber reinforcement and sitting right next to a red hot header they start cracking sooner than most people think. Nothing serious, but just look at it during an oil change.
