The torque value to start a fastener moving again after it has been tightened to a torque value and stopped, can be higher than the torque value to turn the fastener after it has broke free and started to move again. That is why it is so important to torque fasteners in one smooth pull without letting it stop before the final torque value has been reached. The same goes when doing a retorque of the head fasteners. The fasteners have already been tightened and have set. If the torque wrench is set to 80 ft/lbs looking for a 80 ft/lbs final torque, what if it takes 81 or 82 to break the fastener loose? The torque wrench may tell you the fastener will not break loose at 80, but what would the final position of the fastener have been if it was first broke loose and then steadily pulled back to 80?
You're ultimately trying to obtain a certain amount of fastener stretch. Using a torque value to guesstimate the stretch of a fastener is a rather crude method really. That is why checking rod bolt stretch is such a superior method to just torqueing the rod bolts to a book value.
How much friction there is between the threads and the nut or bolt head contact surfaces will dictate how much stretch you've obtained in relation to the torque spec you're using. If the threads and the nut or bolt contact surfaces have taken a set after awhile, it is very likely they will require more torque than the original installation torque to start movement again. That is why it is recommended to first back off a fastener to a lesser torque value first, and then use a steady pull, without letting it stop, back to the desired torque spec.
The reason why there are different torque values for oil and ARP type lubes is because of the different friction coefficients of the two lubes. Slipperiness. ARP lube causes less friction between the threads and nut or bolt contact surfaces, so it takes less torque to obtain a particular fastener stretch value. That alone should give you a clue as to how important that friction at the fastener surfaces really is.
