psycho6cyl
Ponies Are For Lil Girls
- Feb 11, 2005
I love them. I orginally wantes to do DSE drop 2" all around. Decided to buy rims w massive tires and got the usual 1/4 rub. My friend parted ways w his gbody and had these left over. I figured it couldnt hurt at this point. Well these are defintely worth what they are sold for. The spring is a 150 I believe. I was able to get the car high enough where it does not rub. Its not the look I wanted bc I didnt want to trim any panels or moldings. This is a great compromise. Once I established the right height-and yes numerous jacking up and down and test rides. Once I got it where I thought it wouldnt rub I adjusted ride quality-via knob on shock to a harsher setting to see if there was rubbing. There was so I jacked the car back up and made my final adjustment. To have the car not rub for me the wheel well molding had to be 28 1/8" high. To save you guys a little trouble for me w a 28 tall tire I measured from bottom of shock up to lower nut on shock and it measured about 5". Now I have been adj the ride quality knob-w the + and - symbol and the car rides good about 6 or 7 clicks for the base which is turned allnthe way yo negative and gonfrom there. These are the same ones Mark feom TR Custom parts sells. I will def be doing the fronts. Another great product.
Sidenote- I never installes the DSE setup bc I would have def rubbed too much. Not flaming that product just never tested it.
