SignUp Now!Scott-
On Horsepower TV a while back they did a suspension upgrade on a gbody wagon "Sucker Punch." In the front they used the Ridetech Tru turn coilovers with beltech 2 inch drop spindles. Im currently working on this similar project and want to know what is the difference to adjusting the spring on the coilovers to get the stance? To leaving the coilovers alone and lowering the car with the 2 inch drop spindles? I noticed you had the stock spindles and I was planning to do the same.
Thanks for any info on this,
Rodney
Hi Rodney,Scott-
Rodney
Thanks for the info again Scott! Always appreciate your feedback.Hi Rodney,
Not sure why they used drop spindles with the tru-turn system because the tru-turn system is/was designed around using the stock spindles. To achieve their geometry corrections you would want to go with the stock spindles, tru-turn system and then to achieve your desired stance you can adjust it via your coil overs. If you want more in depth explanation or any more info please feel free to call us @ 865-680-4008 we will be glad to take the time to talk to you ...
Scot W.
Give us a call so we can go over all your options and pricing... We give great discounts on complete systems and we have several guy's getting nice 60' times with the Ridetech coil over system... we will go over all of that...Scot
I am looking to get front A Arms and Coil overs, I have been looking at all the systems last few weeks
couple of questions, If I occasionally drag the car how much do you sacrifice 60 foot with these street car performance set ups and can I get the springs in black instead of blue?
If there much of a difference in the UMI versus DSE?
Also any package deals If I buy the whole package at once?
HR rear sway still best one or is the DSE "just as good"
I need this car to handle better than my THS car, the drag car is kinda scary on street with all the trick spring and weight transferring goodies feels like if has hydraulics on it on turns but 60s in high 1.20s
again street car goals on this one but still want to smoke my buddies on Drs
	cool thanks. did you do the install yourself?had ride tech and roc on my car no clearance issues.
yup i did, wasn't bad at all.
You are more than Welcome! Car looks Great BTW!I installed this exact setup in my '87 GN and it drives like a whole new car... and I love the ride height.
I had a few questions and Scot was more than helpful. Thanks again Scot!
The Tru-Turn doesn't really help with the tire clearance as much as the "Muscle Bar" does. The muscle bar has flat ends on it and hugs the front frame to help fit the larger front tire... But to answer your question, it's YES, The trick is to stay right at a 25'' tall tire or Below and you shouldn't have rubbing issues.Scot, I know the Tru Turn helps with tire clearance and says a 275 tire will fit but I am assuming that this is on a 18” wheel. A 235 on a 15” wheel is pretty much the max for the front without rubbing. Would you be able to run a wider tire (than a 235) on the front with the Tru Turn with the stock GN wheels?
Also I know you sold it but your car looks amazing in these posts.
