For peace of mind and extra insurance especially without a dash bar..No, Why? Gussets are mainly used when you cannot get all the way around the weld, 80% by the rulebook.
why not go through the dash, and your rear down bars should have gone to the top of the rear spring pockets.
otherwise it looks great!
Whats the deal with the rear bars? Im only asking cause my buddy is about to cage my limted all i gotta do is buy the chromoly tubes and main hoop...
Exactly!!!! Hes gonna tig it and im gonna help cut,notch and bend the tubes ..... I know how to mig but im not good enough to trust myself welding a cage.....Also make sure your buddy tig welds your cage if you are going chrome moly. If you go with mild steel he or she can mig or tig it in. Chrome moly would be ideal so if you ever upgrade or sell the car it gives you another selling point because you can add to the cage to certify to a faster spec as long as the foundation was done right(location,plates,tube thickness,etc....). Also since chrome moly is stronger you can run smaller size tubing which in turn means less overall weight.:biggrin:
