counterman
- Dec 28, 2006
I am mocking up my "new" combo on the engine stand, and have discovered an issue with lifter body clearance with adjacent lobes on the camshaft. I am using the Comp 210 hydraulic roller with PBM (Morel) lifters. On a lobe or two, I have slight contact with the adjacent lifter body. The lifters are not tapered at the rollers, and measure a full .8415 top to bottom. The cam lobes are lots wider than the old flat tappet I pulled out. The combination of those two plus block build tolerances is giving me the contact. End play is spot on, so I am going to have to modify something here. Either the lifters or the cam lobes are going to have to be cleaned up a few thousanths. I guess that the cam would be easier to modify, as the lobes are way wider than the rollers on the lifters, giving me room to file the sides of the lobes slightly. Cutting the lifter bodies could weaken the roller area, although I doubt it would matter given the little bit involved. Anyone else have this happen before? Just goes to show that you have to check and recheck everything on these motors to prevent a catastrophe. Thanks, Counterman.
