DeltaBravo
Retired U.S. Army/Navy
- Jun 14, 2014
Today I looked into both the low fan relay and TCC systems.
My TCC solenoid is working properly, after verifying 12 VDC at the plug to the side of the tranny either 12vdc on or 12vdc off depending on the brake pedal switch, I took it for a test drive. I verified the solenoids operation by driving at a steady 50 MPH while slightly depressing the brake pedal. Just enough to activate the brake switch and not letting of the gas. I listened for the TCC unlocking which is verified by the PRM slight increasing....which i heard. After releasing the brake pedal the RPM's will drop. So this tells me that the system is working properly....right? And that the ECM is working properly...right?
