SignUp Now!If you are you using the stock solenoid to control your boost them figures will control your boost levels at the different settings .So, I got home and checked my numbers and found: Boost Solenoid DC (1/2) =(84.7), Boost DC (3rd gear)= (80), and Boost DC (4th gear) =(80). Are these the default values because I don't recall ever changing them? Also, what impact do they have on my boost levels? I've been struggling with high boost and now I wonder if this could be part of the problem.
By looking at Daves settings the higher the number the more the boost , I would move one area and log before and after and see how much it moves your boost , the log will show that .My set up is an adjustable actuator with stock solenoid and a bstc boost controller. What is the impact of changing the numbers in the powerlogger pro?
If you're using the BstC for boost control then the power logger won't take control until you shut the BstC off.My set up is an adjustable actuator with stock solenoid and a bstc boost controller. What is the impact of changing the numbers in the powerlogger pro?
Sorry to be dense, does that mean no matter what number I put in the field there is no impact unless the controller is off?
