3.8L V-8 eater
- Jul 22, 2006
I've been following this thread and I'm impressed with what all this chip can do...I was on the verge of buying a classic fast (can't afford a Fast XFI) but this SD2 will be my choice.... Although I'm a little hesitant to put the tuning in my own hands I've read the manual and think if I take it a little at a time starting with the correct set up then move onto idle etc...it will be fine...
I'm getting ready to buy a set of 80lb injectors currently runnning 60's...Going to wait and install the 80's at the same time as the SD2 chip...Over the winter I put on a 6265 CEA to take place of the 6262 CEA and want to go to the track with my current set up and evaluate things before making the change....Has anyone seen improvememnts at the track with the same set up other than the chip change?? Running bottom 11's consistently, but my combo says there is some room for improvement!! I see lots of value with this chip in the drivability and idle department, I see no reason why this chip shouldn't improve things on the time slips as well...
