KLHAMMETT said:Well, during staging i dont have what i would call high temps,At least not enough for detonation,Do you feel ill be detonating at the line around 100*,But not in 3rd gear at 7200 when the intake temp is around 190*???
Tell ya what Bruce,Why dont you stop posting hear, beating up on ecu's that are out there, And go build your own fancy ecu since your so smart,with the proper code in which you see fit,Maybe the guys running in the 6s with F.A.S.T ecus could be in the 5's if you built it![]()
I just want my temps going in my motor while at full throttle to be reasonable to ambient.
And no matter what you leave the line at, you want it as close to ambient during hte run as possible,not a steady climb up!I leave the line no more than 10* above ambient,So my launch temps are not an issue at all.
OK, if your doing comparisons with I/Cs that aren't repeatible, or where the tune isn't optimized, how will you tell when you get the right combo.?.
As soon as the list becomes *your's*, you'll have the authority to invite and others to bow to your desires.
I have my own ecm. I did it for fun, not eveyone is motivated by the all mighty $$$. If you want to pay $2,000 a pop, for a piece that's going to be dated/ obsolete, in a few years, to again be reinvented into the latest/ greatest, and continually spending $2,000 for ecms, that's fine by me. BTW, the latest and greatest of the aftermarkets, are still behind what GM was doing in the GN race cars, in the mid 80's. While they're using faster processors, it's the code that makes an ecm, a *winner*.
If you're not watching the MAT how do you know you don't have a problem?.
At what temp. do you think there is a problem with detonantion?.
It's everyone's dream to run at close to ambient. But, testing to do that (or anything else) means having effective code.
